BreakPoint
Retired LabVIEW features?
I miss being forced to be extremely careful and thoughtful before making any changes to my code. Undo makes it so that I don't need to really think about what I'm doing anymore. Also the fact that I can move a node around without unhooking all the wires first means that I don't have to do as much prior planning. Integration with source control just makes things so much worse.
LabVIEW 2012
Message 11 of 35
(12,611 Views)
And remember when LabVIEW was so easy a marketing person could do it.
(Let the Elijah jokes begin)
Message 12 of 35
(12,581 Views)
@altenbach wrote:
I am curious about the usefulness of more than 63 dimensions. Even if the size of each dimension is only 2, you will break all size limits. This means that at least about half of the dimensions need to be 1. So what's the point?
Oh I don't need them, I was just curious as to how high I could go, (and how thick the lines got)
@PaulG. wrote:
I'm sure some physicist trying to make his math work Smiley Surprised might need more than 63 dimensions. Just sayin'.
Sounds messy.
@Ben wrote:
The State Diagram Editor.
Ben
Looks pretty useful.
@Ben wrote:
The ability to put a VI in the True case of a case structure with boolean Flase to include a VI in memory and simplify loading it at run time.
Ben
That would have solved the orignal question I posted when I first signed up to these forums.
Message 13 of 35
(12,575 Views)
Ben a écrit :
I am going to pis$ myself off posting to this thread but here goes.
I still morn the passing of a wonderful tool!
Ben
I fully agree with you Ben and I can't understand why NI stopped to support this very useful tool. The Statechart Module isn't a replacement.
For your information, I'm still using this unsupported tool with LV 2011 SP1. But with every new version of LV I fear it will no longer be compatible.
Message 14 of 35
(12,564 Views)
Well this one is more of a DaqMX thing then LabVIEW. I miss being able to create Global Virtual channels and just import them and they work. Now if I do not have a card installed I have to create a simulated card or if I unplug the daq card and plug it in somewhere else I have to delete the old device and retarget. They should make these run off of the serial number not when you plugged them in.
Tim
GHSP
Message 15 of 35
(12,542 Views)
Ben
I started a new thread in the LV forum found here to see if we can get NI to start supporting the SDE again.
Please reply to that thread to add your support for the SDE.
Thank you!
Ben
Message 16 of 35
(12,527 Views)
Out of curiosity - does using a static VI reference not accomplish the same result?
Message 17 of 35
(12,488 Views)
(sorry - should have added some context - that was in reference to using a VI inside the "true" case of a case structure)
Message 18 of 35
(12,486 Views)
You can also just replace the boolean constant with a boolean control -  the VIs will then still be included.
Message 19 of 35
(12,397 Views)
old habits die hard.
Ben
Message 20 of 35
(12,390 Views)
