BreakPoint
Rube Goldberg Code
How do you get to know about and understand "coercion dots" as a phrase, but not the reason for a boolean in a loop not continuing to change value after the loop?
https://forums.ni.com/t5/LabVIEW/Blink-function-as-a-SubVI/m-p/4018399/highlight/true#M1149827
Is this caused by a picky teacher?
GCentral
Message 2151 of 2,635
(11,047 Views)
(seen here)
Well, I am sure it's all constant folded so it really does not make a difference, but if you ever need a value of 10 in U8 representation, here's one possibility :D:
Message 2152 of 2,635
(10,939 Views)
@altenbach wrote:
(seen here)
If only this were implemented...ASCII Display otion for U8 (Char?)
GCentral
Message 2153 of 2,635
(10,923 Views)
@crossrulz wrote:
@altenbach wrote:
(seen here)
Only slightly related: The C++17 standard finally introduced a byte type... About time, all those poor programmers had was chars to imitate bytes...
Message 2154 of 2,635
(10,906 Views)
https://forums.ni.com/t5/LabVIEW/verification-of-my-software-code-for-best-practice/m-p/4027167#M115...
I'm not sure if the dude is trolling us or not, but i'm pretty confident 'best practice' doesn't include code duplication, no loops, open vi ref to access callers vi ref to use invoke nodes on caller ...
Includes nuggets such as:
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 2155 of 2,635
(10,858 Views)
/Y
Some others from that same thread
Convert number to string data to save to TDMS. Then when reading TDMS, converting back to number, disabled at the moment.
Message 2156 of 2,635
(10,850 Views)
/Y
But that's clearly a precision issue... Surely you're not saying you're one of those people who store numbers as numbers?! </s>
GCentral
Message 2157 of 2,635
(10,840 Views)
I am one of those people.  And don't call me Shirley.
Spoiler
For those who don't get the joke, go watch Airplane!
GCentral
Message 2158 of 2,635
(10,838 Views)
I want to continue to be sarcastic, but I suppose text files for data are pretty popular.
Not that it applies to TDMS files... 😕
GCentral
Message 2159 of 2,635
(10,835 Views)
Yes, CSV (Comma Separated Values) and tab delimited text files (my preference) are very common.  But if you are using a TDMS file, you should use the natural data type instead of converting to a string.  It is optimized for writing data of different data types.
GCentral
Message 2160 of 2,635
(10,820 Views)
