BreakPoint
Rube Goldberg Code
danil33 wrote:
Same can be easily represented as:
Shouldn't the value wired to N be about 4x less?
Message 1151 of 2,635
(10,714 Views)
Not if the array size is getting bigger and you don't care about checking for running out of memory!!!
This still LOOKs Rube (possibly even not a correct solution I haven't examined it carefully
 - c'mon Christian, show us the REAL solution that uses only 2 base functions!!! - you know you want toSmiley Wink
James
CLD; LabVIEW since 8.0, Currently have LabVIEW 2015 SP1, 2018SP1 & 2020 installed
Message 1152 of 2,635
(10,705 Views)
Hey, I am busy at NI week. Maybe in a few days. 😉
Message 1153 of 2,635
(10,677 Views)
Don't worry, take your time. I guess, you mentioned something like that:
Isn't?
Message 1154 of 2,635
(10,651 Views)
Shouldbe easy enough to clean up with a screen thisbig. Smiley Very Happy
Message 1155 of 2,635
(10,647 Views)
Isn't?
Sorry, but you can do better...
The only thing is that this is not scalable.  It is only good for subarrays of length 4.
Message 1156 of 2,635
(10,664 Views)
Bravo! Just forgot that these functions are resizible... Smiley Mad
Message 1157 of 2,635
(10,654 Views)
Quaoting from mes post above
 - c'mon Christian, show us the REAL solution that uses only 2 base functions!!! - you know you want to:smileywink:
Ben
Message 1158 of 2,635
(10,643 Views)
Yeah, I beat Christian!  That's what he gets for having fun at NI Week while us mortals are stuck at work.
Message 1159 of 2,635
(10,637 Views)
Be sure to make a note in your journal. In my case that (beating Christian) only happens once every five years or so.
Ben
Message 1160 of 2,635
(10,633 Views)
