BreakPoint
Rube Goldberg Code
I think you got a nonzero chance to get a 5 digit number once in a while. You probably should round to -infinity somewhere.
Message 1171 of 2,635
(11,673 Views)
Rounding would ruin your uniform random distribution... probably not enough that you would care.
Josh
Software is never really finished, it's just an acceptable level of broken
Message 1172 of 2,635
(11,626 Views)
That's why you should use the OpenG random number.
http://lavag.org/topic/14981-random-number-integer-numeric-package/page__view__findpost__p__90015
Message 1173 of 2,635
(11,613 Views)
Well, since we convert to integer, rounding will happen no matter what. The original "toI32" will round to the nearest integer, meaning that the first and last possible bin (0000, and 10000) only have half the typical chance of being populated, and some outcomes will have five digits (10000). Stuff like that could kill all casino profits! 😮
If we multiply by 10000 then round down to the next integer, we get equal probability from 0000 to 9999. A truly uniform random distribution for all possible 4 digit integers! That is the way to go and that's what I proposed earlier. And I do care! 😄
Message 1174 of 2,635
(11,610 Views)
My bad, I read the "0-1" and not "less than 1". I was picturing poor ole 10000 with a 1/10000 chance. I should know better, I used RNGs all the time in Matlab. Not much reason to use them in them in test systems, heh.
They need a forum prompt: "Are you SURE you want to correct Altenbach?" with button "I rethought it, NO" and "Your funeral".
Josh
Message 1175 of 2,635
(11,588 Views)
Thanks Christian,
I only needed to generate two random numbers to create unique indexes.
I do like what you suggested and will apply it as a good coding practice.  I also like the openG version.
Since this didn't turn out to be a Rube, it is more of a good coding practice example, maybe it is time to create yet another thread to discuss good coding practice.
Message 1176 of 2,635
(11,569 Views)
So I helped inspire you? At it early I see.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 1177 of 2,635
(11,556 Views)
You always inspire me, Putnam 🙂
Especially with your travels..  🙂
Message 1178 of 2,635
(11,543 Views)
Seems I made my own little bit of Rube recently...
That's what you get for reducing code from somewhere else and not rechecking the logic. (the shame)  Smiley Embarassed
Never say "Oops." Always say "Ah, interesting!"
Message 1179 of 2,635
(11,506 Views)
How many primitves do you need to make a subVI that returns one row and one column from a 2D array?
A single "index array" primitive would probably be sufficient (bottom), but we could also do it using 8 primitives and 4 diagram constants (top)
(seen here)
Message 1180 of 2,635
(11,452 Views)
