BreakPoint
Rube Goldberg Code
@CA The reuse library gets divorced from source around these parts.
Guess what I'm getting paid to do.
@W, benchmark it against anyone's code but Christian's
Message 1891 of 2,635
(11,516 Views)
No need to benchmark Christian's solution, test the two solutions you've already provided and you'll see the non property node method is somewhere around 50 times faster than the enabled case using a property node.  There are of course improvements that can be made.
Oh and removing the write property helps but the non property method is still about 20 or 30 times faster than the single read.
Message 1892 of 2,635
(11,502 Views)
With or without the FP in memory?
Message 1893 of 2,635
(11,473 Views)
Calling it as an inlined subVI, with the front panel closed, taking time stamp information after reading control values, and stopping the time stamp before writing back to the indicators.  Thread swapping is really what kills a property node speed.
Message 1894 of 2,635
(11,464 Views)
That is not what I expected from a p-node property that does not load the FP into memory on an inlined chunk.
I (possibly incorrectly,) assumed that the conversion from
"Bytes" to "String to send to the transfer buffer for display to the user"
would be rather finely optomized
Message 1895 of 2,635
(11,457 Views)
Then of course I caught this gem
Spoiler
Message 1896 of 2,635
(11,440 Views)
On a side note, this would still be a useful idea. 😄
Message 1897 of 2,635
(11,422 Views)
I think the size of the disable structure says enough
Message 1898 of 2,635
(11,394 Views)
Seen here
So we have many cases of a state machine, and every single state is indicated by a particular pattern of three booleans.
Apparently, some think they need to place separate instances of local variables for all three indicators in every single case, and to keep things clean, the terminals should be outside, completely disconnected from the code.
(further comments are in my reply in the thread linked above)
Message 1899 of 2,635
(11,301 Views)
@altenbach wrote:
Seen here
I can rationalize that (but not justify). When you modify the state machine and add another case (to the non-type-def'd enum) you can just right click and choose "duplicate case". If using locals the duplication creates more locals. If using the actual control, the controls will be duplicated.
Ben
Message 1900 of 2,635
(11,271 Views)
