BreakPoint
Rube Goldberg Code
@altenbach wrote:
@Yamaeda wrote:
If you add a U8 to a I32, to you explicitly convert the U8 first? 😉 I mean, the code is more correct, but the extra blocks makes it a little harder to read, since i always think "why are they doing this explicit conversion?".
In addition, an explicit conversion is sometimes more expensive. (Example, but you would think the compiler should create identical code. I have not tested in recent version) 
Debug still turned on? My impression was that the explicit conversion was making more places that could be probed, etc. With debugging off, I would expect identical code.
Message 2631 of 2,635
(525 Views)
In principle, there is still an extra memory allocation of the lower DBL array while the multiplication might know how to multiply an integer with a DBL directly. No time for extensive tests at the moment ....
Message 2632 of 2,635
(511 Views)
Yeah i remember that little nugget. I assume it allocates a new array or something. Maybe Bool to number should have configurable output like the Multiply has?
Qestit Systems
Certified-LabVIEW-Developer
Message 2633 of 2,635
(440 Views)
exactly 😄
Message 2634 of 2,635
(430 Views)
@altenbach wrote:
exactly 😄
It was only suggested in 2009, give'em some time! 😉
Qestit Systems
Message 2635 of 2,635
(353 Views)
