BreakPoint
Site to look at current CARs?
I am trying to find a way to look at the status of current CARs and have so far been unsuccessful in finding anything other than the bugfix lists for product releases. Specifically I am trying to find information on CAR #320545 as I believe I am running in to that issue. Thoughts? Ideas?
Thanks!
(7,512 Views)
There is not a way for people to get insight into CARs in LabVIEW.  All you can do is look for the bug fix in the release documents.  Now just maybe somebody inside of NI will be nice and look up that CAR for you and give you a status.
(7,509 Views)
That CAR relates to special characters not appearing correctly in the Volume License Manager.  Is this the issue you are running into?  If not, what trouble are you running into?
Jesse S.
(7,492 Views)
It isn't an issue displaying the characters. I can't import the .xml file. I am receiving the following error: "The following files were not loaded because they could not be read or are not valid NI VLM Import Utility files:" followed by the file path and name. Both the file name and the computer name in the file have " í "s in them (little accent thing instead of a dot). Searching for this pointed me to http://forums.ni.com/t5/Volume-License-Manager-and/Problems-with-VLM-Import-Utility/m-p/1877255/high... which listed that CAR. Thanks for your help!
(7,484 Views)
Removing the special characters in the computer name within the xml file appears to have fixed the issue. Assuming this is the same CAR, would that be a recommended workaround? Thanks!
(7,482 Views)
I think this is likely a separate issue - I would recommend posting on the Volume License Manager board or calling into support to work with them and try to identify if there is a new CAR. The original CAR you referenced relates specifically to displaying characters and appears to be fixed in VLM 3.1.
Hope that helps,
Jeff Peacock
Product Support Engineer | LabVIEW R&D | National Instruments
(7,459 Views)
