BreakPoint
Stupid me, opened template in project!
Instead of doing "new vi from template" within the project, I opened a VIT by doubleclicking withing the project. After doing a bunch of code I saved, overwriting my template! So frustrating....
Message 1 of 9
(9,172 Views)
Roll back in source code control? :dunno
Message 2 of 9
(9,166 Views)
There are also some ideas related to this. 😄 (hint, hint ;))
Message 3 of 9
(9,159 Views)
I had kudod one, but I guess it was a different one.
Message 4 of 9
(9,150 Views)
Done, but in my opinion it shouldn't be an issue in the first place Smiley Mad
Message 5 of 9
(9,149 Views)
Doh!  Smiley Sad
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 6 of 9
(9,126 Views)
I fully agree you should be able to Right Click New...>>Vi from Template in the project and that wouldn't have bit you.  That is one lonely Kudos there though.....
Message 7 of 9
(9,069 Views)
You can already right click and do this (this being right click, new vi from template). So, I'm a bit confused by the above. But I think a double click should do this by default, and you should have to right click and specify "edit template" I think the two functions should be switched.
I feel the functions should be as follows:
Double click template in project -> opens template and you are prompted for a save as when saving
Right click -> have the option to edit template.
Message 8 of 9
(9,050 Views)
Since I keep my *.xxt files right here
So I can File>>New... like so
I would be able to add files easier to my projects if This
Message 9 of 9
(9,036 Views)
