BreakPoint
Testing AA cells
https://www.youtube.com/watch?feature=player_embedded&v=Y_m6p99l6ME
Reminds me to the rotation test for cooked uncooked eggs ...
Greetings from Germany
Henrik
LV since v3.1
Message 1 of 18
(11,224 Views)
I'll have to try and find two batteries of the same brand to try this out.
Usually a little in-line resistor to put the battery under a load is the best way to tell.
...or if it's a 9V just lick it.  Smiley Very Happy
Patrick Allen: FunctionalityUnlimited.ca
Message 2 of 18
(11,201 Views)
Tried it on my automotive 12V lead-acid battery, ended up breaking the tiles on my kitchen counter.
It must be really good!
-AK2DM
Message 3 of 18
(11,187 Views)
Snopes has a discussion on this, with the bottom entry having a possible theoretical answer to why, if it does, it does.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 4 of 18
(11,180 Views)
Somebody with a myRIO and a strain gauge should build a little test rig to quantify the number of bounces with the charge level.
Discharge the battery over a 1Ohm power resistor, bounce it every minute and record each strain trace on an intensity chart.
(Fully discharged batteries do expand slighly. If you ever left them in a Maglight, you'll notice that they will no longer slide out.)
Message 5 of 18
(11,162 Views)
Things are much easier with the non-cylidrical sizes (4.5V, 9V, 6V, etc) where the contacts are closer together. You just hold the contacts against your tongue and you'll know immediately if there is any juice left. 😄
Message 6 of 18
(11,155 Views)
Never knew of 4.5V, and I think the 6V terminals were more than an inch away so licking might be more difficult.  But then again I haven't seen one in a while.
Message 7 of 18
(11,149 Views)
Just watch out for the 22V photoflash, or some that were higher for running the old portable tube sets!
Putnam
LabVIEW Champion
Message 8 of 18
(11,135 Views)
I've been doing the licking of the 9V battery for a very long time.  I might have done it a few too many times during my tenure at Radio Shack.
Another trick I learned there was to take 2 9V batterys (preferrably when they are already on the low side) and directly connect them.  Makes a really nice hand warmer.  Perfect for these -20F wind chills we have had lately.
Message 9 of 18
(11,134 Views)
I did this once with two 9V batteries as a kid.  The terminals just plug right into eachother.  I had a DC motor near by so I wired it up and I swear the motor spun really fast, and the batteries got really hot.  After disconnecting them both 9V had no juice at all.  Electrically I convince myself that the motor didn't move at all but that's not how I remember it.
Message 10 of 18
(11,126 Views)
