BreakPoint
This is Hooovahh
@Hooovahh wrote:
Oh S*** Stop the bus
I wasn’t involved in this one but...
Well, before my time.  Another acronym was brought into use at the University of Chicago that is still in use today!  The original OSSTB. Safety Cable Release Ax Man (Yup, every nuclear pile still has a SCRAM system)
Message 341 of 520
(4,738 Views)
In the lab we have a big monitor with stuff going on, and recently a corner of it has become available.  With this new real estate I've put up pictures that change every 30 minutes on rotation.  So far I only have 3, but I'm interested in more test related funny images if people have any to share.
Message 342 of 520
(4,658 Views)
What was your rate again?
A friend of mine was really bad with money.  Bad credit, bad purchasing decisions, always strapped for cash.  One day he showed up with a brand new Dodge Challenger.  All of our friends wanted to go for a ride and check it out.  Being the more frugal type I started asking him about it.
Hooovahh: Wow this is a pretty sweet ride.  I know my credit union was giving some amazing rates like between 2% and 4%.
Friend: Yeah I didn’t get that good of a rate from the dealership.
Hooovahh: Oh that’s too bad I mean like 8% or something?
Friend: Well no it was a tad more than 8%.
Hooovahh: Wow so like 15% I can’t believe that it would be so high.
Friend: No it wasn’t 15%, it was just a little more than that.
Hooovahh: I mean a 20% loan on a car these days is just ridiculous.
Friend: Yeah I would have preferred 20%, but it was actually a little more than that.
At that point I just stopped asking.  Apparently since then some laws have been passed to make charging these kinds of rates illegal, or more difficult by basing the lending institution in another state.
Message 343 of 520
(4,609 Views)
Are You Illiterate?
I need the test compliance document for standard XYZ, do you have it?
Yes.
Can I get a copy?
Well the document is over 100 pages, are you going to be able to read and understand it?
Are you asking if I can read?
Message 344 of 520
(4,608 Views)
@Hooovahh wrote:
Are You Illiterate?
Yes.
Can I get a copy?
Only 100 pages?  Sounds a little short.  I have test plans for MIL-STD-810 well over 200 pages.  And I've had week-long "discussions" with coworkers over a single section of that standard about how it applies to our specific UUT.  So, yes, your questions are quite valid.
GCentral
Message 345 of 520
(4,603 Views)
Recently an addendum to LVD came into effect (the EN 61010-1:2010/A1:2019) and we had to check what changed, so our instruments would pass it.
Just the addendum took me and a coworker a day or two to get through (and we mostly skimmed it) and reading it is an effin drag.
Message 346 of 520
(4,579 Views)
@Hooovahh wrote:
Are You Illiterate?
Yes.
Can I get a copy?
We coined a term at my last job when I wrote a failure investigation report over 120 pages long (it was a 6 month investigation). When I handed the report to quality to sign off, he laughed and said it had "thud factor". The louder the "thud" when it hits the person's desk, the less likely they are to read it.
Josh
Software is never really finished, it's just an acceptable level of broken
Message 347 of 520
(4,565 Views)
I hear that as "The better you are at your job, the less likely I am to care."  Or "If you put this much work into it, it must be right, and I don't need to waste my time checking it."
Message 348 of 520
(4,563 Views)
Cheap USB to RS-232
In the LabVIEW world it is pretty common to have to connect to external devices.  And many of those devices happen to be RS-232 or serial.  So a common tool for developers is a USB to RS-232 adapter.  There are several different chips from Prolific, to FTDI, and a few others.  This was years ago when we didn't really have visibility on this, but there are lots of counterfeit chips that are sold on the cheap.  A legit device like this can be a couple of hundred dollars.  But back then we were buying these in bulk.  I don't remember the actual cost of these, or the number of them, but it was something like 50 of them, for $20.  And they came in a large round plastic tub, like what cheese balls come in.  This was the best image I could find of this size of container.
I grabbed one of these, plugged it in, and...nothing.  It wasn't that there were driver issues, Windows just didn't see the device at all.  So I opened one up to see what the problem was.  The dsub connector inside was a solider cup type, and the PCB was shoved between the rows of pins.  The PCB was a two sided board, and had solider points on the top and bottom, with a gob connecting pins to the board.  It was pretty clear to me that the pins weren't making a good connection, and after spending some time fixing it, it worked fine.  So my manager that ordered these sent an email complaining to the manufacture that none of them worked, and the quality of the devices was poor.  I think he was looking for a refund, but instead without, asking for it, a second large tub of adapters just showed up.  At this point he just let it go and figured he wasted $20 on that lesson.  Occasionally when someone was idle, and looking for something to do between tasks, he'd have them repair a couple.  By the way, these were all used for testing, but not put into testers for a customer.
Message 349 of 520
(4,514 Views)
As the old saying goes: You get what you paid for.
I had so many issues with USB-RS232 adapters from 2005 (when I first tried to use one) through ~2013.  It was so bad I refused to use any.  Things have gotten a lot better over the years, and I now use them regularly (mostly because I don't get to work on desktops).  For test systems, I will spend some money and get the industrial grade adapters.  For my own use, I have a couple of $10 TrendNet adapters that have worked for well over 5 years without an issue.
GCentral
Message 350 of 520
(4,503 Views)
