BreakPoint
Touch screen works better than I'd hoped
Just had a chance to install a distributed exe on a Surface Pro. Very slick, so far. Several copies of logic and UI for duplicate controlled motion and sensors. Simple DAQ, this time (USB-6009), and USB-to-Ethernet adapter for UDP. Haven't seen MAX, yet, but someone here was running the LV2012 IDE with USB DAQ (of course an external monitor and a mouse helped a lot.)
Not to try a LV2013 app and see if a control with key focus will change value with a two-finger swipe (mouse scroll).
Disclaimer: I am not a Microsoft employee, but I have done work for them.
(6,500 Views)
I'm trying to use the USB-6009 through Ethernet with a USB over IP adapter (http://www.startech.com/Networking-IO/USB-PS2/10-100-1000-Mbps-Gigabit-1-Port-USB-over-IP-Device-Ser... but NI Max doen't find the device. It does it if it is directly connected through the USB port. You mention a "USB-to-Ethernet adapter for UDP" that you are using. Have you had any success with it? If yes, please, could you recommend me which device you used?
Many thanks,
Alex
(6,163 Views)
I believe I have my answer on the following NI forum:
http://forums.ni.com/t5/Multifunction-DAQ/digi-5-Port-USB-AnyWhere-Remote-USB-Over-IP-Extender-in/m-...
I'll keep looking for an alternative then...
(6,124 Views)
