BreakPoint
UWO's (Unidentified Wiring Objects)
UWO:
a mysterious object seen in LV for which it is claimed no orthodox scientific explanation can be found, often supposed to be a vehicle carrying extraterrestrials.
Not sure about that last part 😁.
I'll post mine here, please feel free to add your.
(3,691 Views)
Ran into this one. Saw it before, but never cared to look further:
I demystified it, but see if you can.
Hints:
It's not the for loop's iteration or conditional terminal
It's a nested part of the VI.
Steps to reproduce:
Spoiler
Make 2 nested for loops
Select the top for loop's iterator terminal
Select Move To Front from the VI's menu
Move the iterator 'over' the other for loop
(Optionally) Hide the iterator.
(3,687 Views)
I see stuff like this from time to time.
First reaction is to scroll the diagram down out of the visible region and back again to see if it disappears, in which case it's just a redraw glitch.
(3,615 Views)
I also see the text "Filter.." often in my front panel.
It seems like a glitch from the quick drop or find dialog.
Of course, catching it in the act is hard when you actually want to.
(3,612 Views)
Here's how I get it:
Create a new VI
CTRL+F
Find anything (text or object)
(3,599 Views)
FYI, the 'Filter' artifact text issue has already been filed to LabVIEW R&D as Bug 2259162 and is scheduled to be fixed in a future LabVIEW release.
(3,578 Views)
I'll probably miss it once it's gone. It has been there for a long time. Since the filter was added to the find results?
(3,545 Views)
