BreakPoint
Unable to control myself from Code cleaning !
There are many situations where I have to develop code within short time, but I am not able to control myself from cleaning the BD.
From some of my fellow collegues I was advised not to care about the wire bends and other stuffs and complete the code. Later part we can cleanup the code, but I am not able to follow this.  Even when I check the code of others and if I see wire bends and mis-alignment I start correcting them.
Feel free to post your opinion.
Message 1 of 21
(9,832 Views)
Trust me, you are not alone.  See this thread on LAVA for some good examples: Anyone else OCD about alignment and positioning in block diagrams?
I am so bad that I usually clean up somebody's diagram just to figure out what they are doing.  I also created a few shortcuts to help me clean up.  And my number one righ-click menu that I use is "Clean Wire".
My opinion is you will never have time to go back and do it right.  Just do it right the first time.  This includes clean up and documentation.
Message 2 of 21
(9,828 Views)
The very same reason I do. Now I have to practice myself doing quick documentation 🙂
Message 3 of 21
(9,821 Views)
I usually find I have plenty of time to clean up while I'm thinking about what I'm going to do next. My biggest source of frustration is deciding what my icon is going to look like. Smiley Indifferent
PaulG.
Retired
Message 4 of 21
(9,819 Views)
@PaulG. wrote:
I usually find I have plenty of time to clean up while I'm thinking about what I'm going to do next. My biggest source of frustration is deciding what my icon is going to look likeSmiley Indifferent
I always use the same template with a heading and body color. I use the same in every project I do, and people easily identify whose code while sharing. Also I am not fancy about the Icons, simple and easy to understand.
Message 5 of 21
(9,817 Views)
You are not alone on this. I got hit a few times by going through "others" coding and which had its positive eefect on my coding style.
Ever had to scroll for a few minutes to see the entire vi?
Message 6 of 21
(9,769 Views)
Not on my code Smiley Wink Only a few times when I had to see the code, posted in forum.
Message 7 of 21
(9,764 Views)
Yup, doing it all the time. It's quite annoying when you've spent some time making a VI look nice, compact and stylish just to open it in a later version of LV where the default font is increased and all alignments are lost!
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 21
(9,763 Views)
How many of us have opened a example from the example finder, and then spend a few minutes cleaning it up?  I always stop half way through.  Of course in 2012, and 2013 NI have been improving their examples but still there is some coding preferances that I find myself doing like terminals on the side, and labels on the terminals being transparent.
Message 9 of 21
(9,727 Views)
I had heard/was taught that "template" icons with english descriptions was frowned upon. Your template method makes a ton of sense. I don't know how I got sucked into making icons "easy to understand" pictures. I guess the old school wants to make icons look like primitives.
PaulG.
Retired
Message 10 of 21
(9,711 Views)
