BreakPoint
User name changes
This is a rather insignificant question, and it really didn't seem to fall into the scope of the other boards. How would I go about changing the identifying information LabVIEW holds such as the user name and company name? If our company has changed names, where and how would I edit that information in LabVIEW?
Paul
(4,259 Views)
You can change this information in the registry, but I have no idea if it's legal to do so like this and I don't know if you will be able to start LV afterwards (although I assume you will be able to, at least in pre-8 versions).
Open the registry editor (start>>run>>regedit) and navigate to HKey_LOCAL_MACHINE\SOFTWARE\National Instruments\LabVIEW\your version and you will find the appropiate keys. Note that playing with the registry can be very dangerous if you don't know what you're doing. Do this at your own risk.
___________________
Try to take over the world!
(4,248 Views)
