BreakPoint
What are macros?
I did a search - honest. I even looked at the help but was unable to find out what macros are. I probably can not find it because it is right in front of me.
LabVIEW 2012
(11,248 Views)
Hey Steve,
Macros let you create customary text that you can paste into any message just by selecting from the drop down menu. Here are a few points straight from our vendor's help page.
To use a macro when you post:
  1. Go to a Post page. The Macros menu is on the right side of the Post page toolbar. You can use a macro in any sort of post: a message, a reply, a comment, an idea, you name it.
  2. Click in the Subject or Body area where you want to paste the macro text.
  3. Choose a macro in the Macros menu.
  4. The text of your macro appears wherever your cursor was.
To use a macro when you write a private message
You can use macros in private messages just as you can when composing a post elsewhere in the community. Once you have defined a macro in your profile, you can select it from the drop-down list that appears at the top, right-hand side of the editor:
Note: If you want to have special text at the bottom of post, you can put that text in a signature instead of a macro.
Hope this helps!
Jordan
Forum Moderator
(11,244 Views)
I have various macros to insert HTML codes so I can get line breaks and spoilers from my iPhone.
(11,230 Views)
Awesome. I never saw the macros dropdown because I guess you have to actually have a macro for it to show.
LabVIEW 2012
(11,210 Views)
I have all possible ones defined. I just wish there were more of them available.
(11,199 Views)
You can now have 15 macros instead of only 9 Smiley Happy
(11,086 Views)
Thank you!
(11,073 Views)
