BreakPoint
What hardware do you regularly use with LV?
MIO. We have one or more at a test station, maxing out the channel counts with regularity.
We use them to in our closed loop control systems (ugh), but because our response times are in the 10's of ms range or higher, it all seems to work out OK. Gives me the heebie-jeebies though. Doing this stuff in Windows makes me nervous as h-e-double hockey stix.
I know, I know... but please don't spam me with suggestions for using RT or LV FPGA. I don't control the purse strings around here, and really dislike sales pitches. I would switch over to a PLC anyway if these suckas weren't drowning in the LabVIEW KoolAid.
Message 11 of 20
(6,961 Views)
@altenbach wrote:
Well, one of my computers (120 MHz Pentium I, 64MB of RAM, 1GB HD) still uses an AT-MIO-16E-1. (ISA bus!!! for those who remember). Since a single device under Windows 95 only allowed a limited number of DMA channels (if I remember that right), it actually shows up as two devices in the device manager. 😉
I remember those.  Wasn't there an AT-MIO-16E-10 also?  That card was the first NI card I ever used and I m anaged to blow a few of the digital ports during my experiments by connecting things wrongly....  Never told my supervisor though... Smiley Embarassed
I think even with the ISA bus we were using only a fraction of the capabilities back then.  Although I don't have any of it anymore, I think looking at my LV code from back then would either frighten the life out of me or give me a good laugh, depending on what kind of mood I'm in.
Message 12 of 20
(6,947 Views)
My first project was a test-setup with a SCXI rack with I/O modules and LabVIEW 4.
I still build some test-setups. All built with different hardware.
Two pictures (1 and 2) shows a tester with a PXI rack (from Pickering) with NI and Pickering HW. This tester was built to test over 30 different modules (with different pin layout) at the connector at the right lower corner. At picture 2 you can see a testficture for an additional module.
Picture 3 is showing a tester with equipment connected through GPIB. Behind the equipment a DAQ chassis (DAQ-9178) to connect to the different 24V I/O.
Picture 4 shows a tester with Equipment from Agilent (PSU) and Yokogawa.
So many different solutions for various applications.
Kees
Message 13 of 20
(6,927 Views)
pictures?
Message 14 of 20
(6,919 Views)
The numbers are hyperlinks to the pictures, but I don't know if thsi will work for others.
Message 15 of 20
(6,915 Views)
Yes, they seem to work now. (site is extremely flakey today....)
Message 16 of 20
(6,909 Views)
Not able to post pictures..... But my applications have been high-accuracy measurements of DC current and voltage to verify test equipment performance. Also have done temperature measurements using RTDs as sensors.
Use PXI-4071 DMM for VDC and 4-wire R/T measurements. Use PXI-4141 4-ch SMU for zero-burden DC current measurements.
Use PXI-2530 multiplexers to enable testing of a large number of sources on the equipment and PXI-2569 relay to provide a continuous current path for each the sources when not measuring its current by selecting its multiplexer channel.
Interface between the PXI modules and the stress equipment is handled by PCBs and custom cabling that I designed and procured, and can be used either actively to drive the DUTs individually from the SMU or DMMs or passively to act as a "fly-on-the-wall" verification of stress conditions applied by the equipment.
Jeff
Jeffrey Zola
Message 17 of 20
(6,840 Views)
@crossrulz wrote:
But one of the coolest things (at least I thought is was really cool) was using the PXI-7813R to generate a sample clock for the PXI-5421.  With that setup, I was able to take a customer supplied waveform and do a frequency sweep with it.
I do like those FPGA cards too, and am interested in seeing what the MyRIO can do in comparison.  There is something pure when dealing with FPGA programming that I enjoy.
That being said you can perform a hardware timed frequency sweep using a counter output too.  Of course I don't know the whole picture so maybe using this method was not an option for some reason.
https://decibel.ni.com/content/docs/DOC-32352
EDIT: and to stay on topic I deal with alot of MIO cards.  PCI, PXI, switch matrix, CAN, LIN (XNet), serial (power supply, UPS, frequency generator interface), some Arduino, cDAQ, SPI, and some FPGA.
Message 18 of 20
(6,769 Views)
The hardware I use most are probably a pen and paper followed by my coffee cup.
The longer I program LV the more I tend to grab my pen and paper before writing any code at all.
Than we have several different RT Systems, FPGA cards and so on.
Message 19 of 20
(6,752 Views)
Not to mention the coffee cupSmiley Very Happy
Message 20 of 20
(6,734 Views)
