BreakPoint
What is this and what is it used for
@GovBob wrote:
It's part of one of these.
... and if you read the write-up Bob linked you will find the phrase "Stainless steel sieve ..."
as in "Sieve of Eratosthenes" whcih I belive Christian used to kick-bu@# in the Prime Number LabVIEW challenge.
Ben
Message 11 of 294
(12,132 Views)
Well, I wasn't too far off!  At least I had the intended motions and the principle that it was for manipulating soft organic material right.
Message 12 of 294
(12,115 Views)
Next Challenge (more in the broad sense of things):
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 13 of 294
(12,102 Views)
EASY!
Why, Thats a "Rabbit in a hat!"  Its presented to prospective candidates for NI Certification as an NI Certified LabVIEW Consultant (Without any documentation) and, pulling the rabbit out of the hat is the final exam criteria for admission into that select group!
Message 14 of 294
(12,096 Views)
Close... 🙂
Kind Regards,
Message 15 of 294
(12,068 Views)
Old school I am much better with....
A rubber glove in a .... looks like the recease that used to be used on the back of speaker cabinets so the phone plug could fit in and still sit flush against a wall...
Ben
Message 16 of 294
(12,045 Views)
Nope,
It is all "hard" plastic and the rabbit head can move. 🙂
Kind Regards,
Message 17 of 294
(12,038 Views)
What is the size of this thing?
Looks like a bottle closure.....
Norbert
Norbert
Expert: Geometry
Message 18 of 294
(12,035 Views)
The height is around the same height of a 33 cl soda can.
It's diameter is (except for the bottom of the hat) much smaller.
A tip:
The hat itself contains objects that become visible by pulling the rabbit out of the hat.
Kind Regards,
Message 19 of 294
(12,016 Views)
@ThiCop wrote:
A tip:
Sounds like a gum ball machine
GCentral
Message 20 of 294
(12,008 Views)
