BreakPoint
Why some people say Local Variables are bad...
Ray.R wrote:
Yes...  There are many pitfalls..  Maybe like you said, we could have a sub forum. However, we would not want to give the idea that LabVIEW has pitfalls..  All programming languages do..  It's the programmers that create the pitfalls... 😉
Maybe a sub-forum called "Gatchas"...  LOL!  😄
Good point that.
"How not to do it"
_____________________________
- Cheers, Ed
Message 271 of 396
(8,058 Views)
And now for another example of the pointlessness of the locals:
The other cases in the event structure are basically the same.
from here:http://forums.ni.com/t5/Version-Conversion/Request-to-downconvert-VIs-from-8-5-to-7-1-post-2-2/td-p/...
Message 272 of 396
(7,999 Views)
The correct link is actually here.
Even funnier is the timeout case for the UI. It basically tickles most indicators every 100ms. None are connected, because they are all updated via locals elsewhere. Why? Why? Whyyyy? What a waste of CPU cycles. Omitting the timeout case entirely would not change a thing! 😄
Message 273 of 396
(7,984 Views)
Thanks for the link correction, altenbach.
Yeah, I got a chuckle out of the Timeout case when I first saw it as well.
Message 274 of 396
(7,959 Views)
Message 275 of 396
(7,943 Views)
@nathand wrote:
How about the first frame of this sequence:
Typical text programmers! 😄
That almost looks like "Local Variable Russian Roulette"! 😮 (A big step above a simple race condition). For the "Temp data array" we have three readers and four writers nearly concurrently.
You covered the problems nicely in your reply. In addition, I would recommend to transpose before the complex to RE/IM: Only one instance needed.
Message 276 of 396
(7,975 Views)
Not only was this one a Rube Goldberg example, it is also an example of Locals abuse. Locals as in Local Variables, not people in the vicinity.
(Seen here)
Message 277 of 396
(7,883 Views)
More localitis and sequenceitis (as Altenbach put it).
http://forums.ni.com/t5/LabVIEW/String-box-rejects-input-after-built-with-App-Builder/td-p/2017204
Message 278 of 396
(7,806 Views)
there is worse than locals... take a look at the VI attached in this posSmiley Surprised
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 279 of 396
(7,796 Views)
My browser's encoding must be off.  I can't understand anything in that post!
Jim
Message 280 of 396
(7,792 Views)
