BreakPoint
Why some people say Local Variables are bad...
DAQ Assistants Suck! Smiley Tongue
Richard
Message 191 of 396
(8,362 Views)
I would like to thank newbieboy for a beautiful example of a race condition, which can be found here.
Oh yeah.. I forgot that the snippets have the same feeling towards locals as I do.  In the original code, it is a Local Variable of the x=y? indicator that is wired to the Case Statement.
Message Edited by Ray.R on 05-04-2010 08:26 AM
Message 192 of 396
(8,268 Views)
Not if you use the CCT to create them. It manages just fine with both locals and property nodes.
Message Edited by tst on 04.05.2010 04:17 PM
___________________
Try to take over the world!
Message 193 of 396
(8,259 Views)
Of course, the beauty is that it's still a race condition even with the reference!
Message 194 of 396
(8,248 Views)
If you use the Code Capture Tool, can you also drag it into the block diagram like the code snippet?
Message 195 of 396
(8,237 Views)
No.  Code Capture Tool is just a picture.  But at least its a real picture and doesn't discriminate against local variables like we do.
- tbob
Inventor of the WORM Global
Message 196 of 396
(8,241 Views)
Despite what tbob said, you can, at least in modern versions of the CCT. You're welcome to try it with the snippet I posted earlier.
Incidentally, the CCT supports snippet creation for any version from LV 7.0 and up, and there's a JKI plugin which will allow you to import the snippet, which works from 8.2 and up.
You can find the CCT here, with some videos which show the new features. If you want direct access to the videos, they should be here.
___________________
Message 197 of 396
(8,234 Views)
Well... I'll be a flying swordfish...
It worked..  I'll definitly switch to it.
Thanks tst
Message 198 of 396
(8,215 Views)
Sorry.  I had no idea CCT would do this.  I must have the old version.  Switching to the new right now....
Well... I'll be a flying squirrel.  It creates snippets. Smiley Happy
Message Edited by tbob on 05-04-2010 12:58 PM
- tbob
Message 199 of 396
(8,206 Views)
tst wrote:
[...] and there's a JKI plugin which will allow you to import the snippet, which works from 8.2 and up.
The JKI RCF plugin is here.
Jim
Message 200 of 396
(8,199 Views)
