BreakPoint
Why some people say Local Variables are bad...
@Ray.R wrote:
Local Horror!!
Discussed here
The locals span 3 screens down!  The code is incomprehensible..
Did you notice that he even connects a local variable to its own terminal near the top left?
Curiously, none are needed. Here's equivalent code, replacing the entire inner code on the left.... 😄
Message 361 of 396
(8,604 Views)
I had to clean my glasses after glancing at the block diagram..    😮
Message 362 of 396
(8,588 Views)
I threw up in my mouth a little bit.
Message 363 of 396
(8,578 Views)
Ohh......ooooooooooohhhhhhhhhhhhhhhhhhhhhhhhhhh
That's bad!!!
Spoiler
I'm referring to the Locals, of course!  😄
Message 364 of 396
(8,569 Views)
That's for when you want to be *really* sure that you have set the right value properly. You know, for nuclear reactors and such.
___________________
Try to take over the world!
Message 365 of 396
(8,559 Views)
Arrays? I don't need no stinking arrays.
Ooh, look at this I can make a cluster.
I need to do stuff with the data! I'll change it to an array!
_____________________________
- Cheers, Ed
Message 366 of 396
(8,430 Views)
I like the comments.  I usually use Free Labels, but String constants are pretty sweet.
Jim
Message 367 of 396
(8,421 Views)
At a glance what you posted is only about 10% of the entire block diagram. What a fracking nightmare. Smiley Surprised
PaulG.
Retired
Message 368 of 396
(8,418 Views)
  • Usually, we see it the other way around. "Array...array to cluster...unbundle"
  • I like that purple spider web on the left.
  • I have the feeling that the time formatting in the upper right could be done with a single primitive and a slightly more complicated time format statement. 😄
Message 369 of 396
(8,412 Views)
@altenbach wrote:
That must be there to catch any bugs 😜
Message 370 of 396
(8,393 Views)
