BreakPoint
code capture tool
Hi All,
Currently, i have a version CCT_1.0.0_137 but it cant be used it labview 8.5. Will prompt out an error. I found in internet are all these version, and is suitable for labview version 7.0x. Is there any code capture tool that is suitable for labview 8.5, is the latest version? I need it very urgently. Hope to hear the replies soon.
Thank You Very Much.
Happy Lunar New Year (:
Isa
(8,826 Views)
It should work in 8.5. What kind of errors do you get?
(8,824 Views)
As Altenbach said, it should work fine in 8.5. If you want to make sure, you can download the latest version from here, and I believe you should have the latest version. If I had to guess, I would say you tried opening it from the getting started window, which won't work. You need to open it from a VI. There's a video on the page I linked to demonstrating how to use it.
___________________
Try to take over the world!
(8,813 Views)
The proper routine should be:
Download latest zip version from LAVA.
Run the  install VI and it should work after a restart.
Ton
My LabVIEW Ideas
(8,812 Views)
One thing comes to mind, is your LabVIEW data folder available?
The CCT uses this folder to store some settings in an INI file.
Ton
My LabVIEW Ideas
(8,784 Views)
Error 1 popped out. Below attached the screenshot.
(8,765 Views)
It looks like it goes wrong when the file is saved.
What is the folder that stores the images, try to setting this to a known location with the browse buttton.
Ton
My LabVIEW Ideas
(8,760 Views)
