This presentation talks about Application frameworks/reference designs that can be reused. Most of the times applications are developed such that the frameworks from one project is not reusable for next project as the components are tightly coupled with the application.
There are lot of frameworks available in the community, but many of us are not aware of them. These frame works are used in many applications and it has been tested several times. so these are best references or designs to start a new project.Application specific code alone needs to be added to these frame works, to make them complete application
Based on the reference design you planning to reuse you might need LabVIEW add-on modules and different hardware.
The Presentation is available in the form of PDF attached with this document.
