CLD Summit Presentations
Actor Oriented Programming in LabVIEW
Overview
 Understand how LabVIEW Actor framework works. How to send messages between actors. and also perform different task based on the message data.
Description
 Learn how to create multi loop application more efficiently using LabVIEW Actor Framework.
Hardware and Software Requirements
 LabVIEW 2016 or Higher
1> Open the project. Run the launch.vi
2> Click on Open chat box from Shubhajit and Anna both Actors.
3> Send Messages from Shubhajit's Chatbox to Anna to see automated Reply by Anna.
Example drama script -
Hi
Good morning
how are you
i'm fine
what can you do for me?
ok, tell me a joke
what !
ok fine
bye
Additional Information or References
 install Windows Speach SDK 5.1 which can be found  @
https://www.microsoft.com/en-us/download/details.aspx?id=10121
Comments
சிவபாலன்
Member
Member
on
Hi
The PPT is not opening properly in my system. Can you convert as a PDF and upload?
Sivabalan Veluchamy
meBaga
Member Member
Member
on
Ajay_MV
Active Participant
Active Participant
on
Hi Subhajith @meBaga,
I got a chance to look at your example (Drama.lvproj).  That's attractive example as it shows up as artificial intelligence example where computer responds to our messages.  🙂  Thanks for that.
I was looking for the abstract messaging (of AF messages) in that example.  Is that example implemented with AF abstracted messages?
I assumed abstracted messages should be implemented with inherited classes from AF-message class.  Am I missing something here?
I thought that the message should be dynamically dispatched as like below.
There is no inheritance of message class
Ajay.
Ajay MV
meBaga
Member Member
Member
on
Hello Ajay,
Sorry for late reply, correct me if I have misunderstood your doubt.
In this case the Actor messages are not inherited from the Actor class not from each other also. Each messages are inherited from the Actor Message class. The Root Actor is used to launch the two nested actors and each actor has their own message.
As the property of the Root actor and the nested actors are not same, they must not be inherited. These actors and messages are independent of each other making low coupling between them.
Also for your reference ,
In OOP Scenario, when a class is inherited from another class, the relationship is called "Parent Class - Child Class"
In Actor Framework, when an actor launch another actor, the relationship is called "Root Actor - Nested Actor"
Contributors
