CMC Driver Framework
Genesys: Over Voltage Protection Enable not implemented
A TDK-Lambda Genesys power supply always has Over Voltage Protection enabled. As such, the enable/disable/query capability is not available. However, the Set Voltage function will return an error if you attempt to set the voltage above 95% of the Over Voltage Limit.
Will
CLA, CLED, CTD, CPI
LabVIEW Champion
Choose Movement Consulting
choose-mc.com
Message 1 of 1
(2,216 Views)
