CMC Driver Framework
Torque Tools: Localization doesn't work when the example is built into a PPL.
In the DFTT Torque Tools Demo and Build Example in the example finder, we included a localization option to change some of the nomenclature that is different between some of the common torque tools.  Those are built into a PPL and deployed with the driver.  If you run the example you will be able to switch between them.  If you then proceed to build the example into an EXE or PPL itself, the localization may not work.  The reason for this is that we were able to make the software detect if it was built into a PPL and get the appropriate paths that way, but in the time before the release we were not able to devise a method of determining whether the PPL is inside of a PPL.  If you want to have a specific nomenclature as a part of your example, either don't built it into a PPL or run the example beforehand and apply the localization you want and then save the VI with those defaults.
Message 1 of 1
(1,728 Views)
