CSLUG - Central South LabVIEW User Group (UK)
Meeting Tuesday 11th December 2018
Thanks for the video Steve.
Thanks and Regards,
Supreeth.K
Message 11 of 14
(2,607 Views)
Steve,
So to add a little formality to my blase' comment "I'll talk about IDE extension" let me be a bit more specific.
I thought I'd share with you lovely people a little tool I created to make VI Analyzer more accessible both literally and form a psychological point of view. I'll show how I implemented this using Project Providers and a little VIPM goodness.
Looking forward to seeing everyone
Chris
Don't forget to give Kudo's for a good answer !
LabVIEW Champion
Certified LabVIEW Architect
Certified TestStand Architect
Message 12 of 14
(2,572 Views)
Hi all
it was nice to see you after long time.
I would like to share with you static/dynamic loading subPanel VIs to memory as we discussed it. See attached code:
  • static reference will break main code when subPanel VI is broken
  • static reference will sort-out VI rename
  • static reference will add VIs to EXE build
  • for not-implemented subPanels dummy VI (Template) is be used
  • one For Loop will load all subPanel VIs
    • when subPanel VI FP is still open (during development process) FP.Close and Abort will sort it out
    • VI.Name property will return name of subPanel VIs
    • and each will be opened and started and forgotten (queue message will be used to close them down when application is closed)
    • different part of code will insert new subPanel VI to subPanel Control (and remove previous one)
 Load Static subPanelsLoad Static subPanels
 See you next time.
 Peter
Message 13 of 14
(2,509 Views)
I thought it was a great meeting this time. Thanks for taking the time on that, most illuminating.
don't be a stranger Mr J
Steve
Opportunity to learn from experienced developers / entrepeneurs (Fab,Joerg and Brian amongst them):
DSH Pragmatic Software Development Workshop
Random Ramblings Index
My Profile
Message 14 of 14
(2,501 Views)
