Certification
CLAD Preparation exam/ Fundamentals/ question n°4 Why B is not a good awnser ??
Hi
Can anyone explain to me why B is not a good awnser ?
I tested the VI and it gives me exactly like the graph in the picture.
But in the response they mentionned only D as a the right awnser.
(6,202 Views)
Accepted by topic author Oussama_Zaidi
It looks like the Build Array primitive in B is set to concatenate inputs so you only get a single plot as a result.
Andy
(6,185 Views)
Sure, you've made mistake in your test. Compare two "build array" functions in this snippet
(6,179 Views)
Thank you
I didn't activate the concatinate option so I obtained the first graph.
(6,171 Views)
Yes that is it.
Thank you
(6,169 Views)
Technically C can also be an answer. First 2 graphs (rows of the array) are correct, 2 other plots (zeros) can be hidden in graph properties. We do not see they are not hidden, so we can assume they can be.
(6,094 Views)
