Certification
CLD Style and Documentation
Hi all,
From what I have gathered reading this forum, a lot of people are not able to create a completely functional program within the 4 hours.   When I take the exam, I would like to ensure that if I am not able to do the same, I would like to at least get all of the points for Style and Documentation.  So far, this is what I think I should focus on, in terms of Style and Documentation:
  • Labels on appropriate wires within the main and subVIs.
  • Descriptions for each algorithm.
  • Fill in "Documentation" section under "VI Properties" for all VIs.
  • Add tip strips and descriptions for front panel controls and indicators.
  • Labels for constants.
  • Straighten wires as much as possible.
  • Create an icon for the main VI and leave the connector pane blank.
  • Create icons for subVIs and set terminals to "Required" or "Recommended"
That is all I could think of as of now. Is there anything else that I am missing?
Any help would be greatly appreciated.  Thank you!
(4,150 Views)
Also, wrap every subVI in an error / no error case structure. I think you can finish in 4 hours, you should run through the practice tests a couple of times. Keep practicing until you finish around 2:45 - 3:00, and you should be in good shape, giving yourself time to understand the new prompt you haven't seen before.
(4,131 Views)
Hi all. Actually, based on  Darren Nattinger's presentation " An End to Brainless LabVIEW Programming, we have removed the requirement for error/no error wrapper on all SubVIs from our evaluation of CLD exam Style/Documentation.
Certification Engineer II
Certified LabVIEW Developer
(4,121 Views)
