Certification
CLD attempt #2 Sprinkler
I made a second attempt at the CLD practice tests.  This time I did the sprinkler control system.  And I'm uploading a solution with an hour and three minutes left on the clock.  I'm not 100% sure how I feel about that, but I hate going back and second guessing myself.
Maybe someone could give me feedback on any area that could have taken more attention?
Thanks in advace,
Bart
(3,565 Views)
Programming Syle Notes
statemachine, init case, unclosed reference
hide abort button (use "top-level application window"? appearance)
ZoneCluster.ctl type def enum exists but has no callers
Documentation Notes
water pressure sensor value change event - no comments inside case strcuture
Functionality notes
timer resets on water pressure value change even if value stays in a good range
(3,556 Views)
