Certification
CLED sample exam using RIO evaluation kit.
Please evaluate and advise any recommendations for my solution. I used sbrio-9636.
I took 4 hours exactly, and used cRIO sample project for data logging.
(5,299 Views)
Can You Please Upload it for 2015 or 2016 Labview Versions
(5,240 Views)
 No Sorry, only 2017
(5,228 Views)
You can save project for previous version from File menu
(5,119 Views)
I Review the exam and I See that your solution is based on a Compact RIO Template shipped with LabVIEW , which is great and will save you a lot of time.
But I think you have to clean the code from section that you don`t need in the exam.
also I don`t know if we will be provided with FTP Username and password for the exam kit or not , so i suggest that you prepare plan B by creating file server using TCP or Network Stream .
Good Luck in you exam and thanks for sharing your solution with us
(5,116 Views)
