Certification
Clarification on ATM 2013 example for CLA
Looking at the example solution for the 2013 ATM, I'm a bit confused.  Is it really possible to pass the test with only a simulation when the requirements request you have the option to switch from simulation to hardware?
CLA
(956 Views)
For the CLA exam, it’s crucial to demonstrate your ability to design a scalable and maintainable architecture that can handle both simulation and hardware modes. While the example solution might focus on simulation, the key is to show that your design can be easily adapted to hardware. Here are a few tips to help clarify:
  1. Modular Design: Ensure your architecture is modular, allowing easy switching between simulation and hardware. This can be achieved by using abstraction layers or interfaces that separate the core logic from the hardware-specific implementation.
  2. Configuration Options: Include configuration options in your design that allow the user to select between simulation and hardware modes. This can be done through configuration files, user interfaces, or initialization parameters.
  3. Testing and Validation: Even if the example solution focuses on simulation, make sure your design includes provisions for testing and validating the hardware integration. This shows that you have considered the full scope of the requirements.
  4. Documentation: Clearly document how your design supports both simulation and hardware modes. This includes explaining the steps needed to switch between the two and any assumptions or dependencies involved.
By focusing on these aspects, you can demonstrate that your solution is robust and versatile enough to meet the exam requirements. If you have specific parts of the example solution that are confusing, feel free to share, and I can help clarify further!
Sathish Kumar A
Certified LabVIEW Architect (CLA)
(845 Views)
