12-22-2011 06:11 AM
Hi
I am planning to take the LabVIEW exam, I want to know the cost of exam.
is LabVIEW Basics I and II manual are sufficient for the preparation of the
exam as we have have them in the LabVIEW Academy.
What is difference between LabVIEW Core I , II (mentioned in the syllabous material of CLAD Exam) and LabVIEW basics I and Basics II
12-22-2011 06:27 AM
I would have thought it would be better to contact your local NI representative direct.
12-22-2011
10:17 AM
- last edited on
02-03-2025
02:18 PM
by
Content Cleaner
Hi illa,
Ray is right, the best way to get pricing and scheduling information is to contact the NI India branch directly.
However, as to your other questions:
That being said, the LabVIEW Basics 1&2 manuals will still be a great way to familiarize yourself with the LabVIEW Programming environment. I recommend the following plan to prep for the CLAD:
After you know the material, this Discussion Forum has other posts on preparing for the exam. You can watch the Preparation webcasts and try the 2 Sample exams to get a feel for the type of questions you will be asked. And there are some helpful blogs we have listed.
Good Luck!
Mallori
12-22-2011 01:10 PM
Thank you very sir.I got an idea about how to prepare.
12-25-2011 11:09 AM
Remember, the CLAD tests your familiarity with the development enviornment. One good exercise for CLAD preparation- that is unmentioned in the materials online (HINT: Tip ahead.) Go through each Function palatte with help on- If you have never used the function before, drop it on a Block Diagram and wire it to some FP objects.
Learn the controls palatte the same way. ~~~SEA story.. I had used LabVIEW for 10 years when I sat for the CLD exam! Of course I know the IDE right?
I had to use the search function to find this so called "Combo-Box" control mentioned in the software specification- I'd never used one before.
Ah the joy of learning!
01-09-2012 11:28 AM
I think this nice info about Courses in India but I need to know about more if you want that visit below website
01-10-2012 09:17 PM
NO, learn the LabVIEW IDE- get your CLAD
Prove you can apply youre knowledge of :LabVIEW to "design" an application and ... you are a "CLD"
demonstrate your mastery of LabVIEW as a programming language get your CLA
12-21-2016 10:47 AM
What the Fee for the CLAD exam in INDIA
12-21-2016 11:11 AM
Best source will be to contact the branch directly.
http://www.ni.com/contact-us/en-in
They will be able to determine your situation and give most relevant and reliable information.
