Certification
Create a Project for CLD?
While preparing for the CLD I've noticed the sample exams say "You must maintain the folder hierarchy..." that is provided on the USB stick.
Does that mean I shouldn't create a Project for my vi's?
Or would that be bad style?
Thanks!!
Adam
(6,987 Views)
Accepted by topic author adam_f
You should definately be using a project.  A project and file heirarchy are two totally seperate things.
(6,986 Views)
Thanks!
(6,983 Views)
WOW
You've hit a "Pet peeve" of mine.
Projects are essential for organizing code components.  Libraries are essential for reusable code.
I see too many "Readme.vi"s and way too many broken projects in SCC because the developers avoid using projects.  WORSE, I see too many files with names like "MPJT_Verb_Noun_WithError+(Datatype).vi.s"  that could be renamed to "Read File.vi"" in "Specific file type.lvlib(p)" on "MyProject/<MyTarget>" vi with error handeling"  or in proper english "Do Act" to "What" in "Scope" on "Target" from "Framework Template". Projects are essential to scope
(6,966 Views)
