Certification
FGV Timer
        I am trying to copy one of the "FGV Timer.vi", but there are lots of errors in the block diagram:
        1. The "time target" shift register is not enabled.. the line is dashed..I simply added a shift register, is it correct?
        2. on the right side, "has time elapsed" has a bad terminal.. maybe it is related to the first question.
         Thanks so much!
Message 1 of 11
(4,824 Views)
Hey,
  1. You haven't connected any data to your shift register. LabVIEW doesn't what type of data you use so he just shows a black dashed line... Send something to the shift register inside your loop or just initialize it.
  2. Hover over the red cross and it says "Wire: Wire has loose end" > the wire is not connected to anything.
CLAMaxime -- Kudos are a great way to say thank you
Message 2 of 11
(4,821 Views)
thanks.. but the sample VI that I copied from, that Register did not connect to anything.
then, how to initialize it?
Message 3 of 11
(4,817 Views)
I connected it to the " time target" indicator, as enclosed..
but it did not seem right for me since it is not the same in the sample VI.
Message 4 of 11
(4,815 Views)
What sample VI did you use ? I highly doubt there was nothing connected to the shift register inside or outside the loop.
Example here :
Message 5 of 11
(4,814 Views)
CLD 3 and 14 in the success package..
Message 6 of 11
(4,812 Views)
The command highlighted is sent into the shift register inside the loop, thus setting the data type used by the mentionned shift register.
Message 7 of 11
(4,809 Views)
THanks, but how to do it?
I still get the dashed line, if I disconnect the register to the indicator..
Message 8 of 11
(4,805 Views)
CLD 3, look at the Start Timer case 😉
Message 9 of 11
(4,803 Views)
thanks so much.. problem solved:)
do we need to put the "default case" as the first case always?
Message 10 of 11
(4,799 Views)
