Certification
Is there a proper way to "tag" comments with requirements for the CLD (sort of like for the CLA)?
Is there an agreed upon way to tag certain comments on your block diagram to signal to the grader that it is the location that satisfies some specific requirement? I am asking for the CLD, NOT CLA. I don't recall seeing any such instructions in the sample exams, but those are sort of old by now, maybe even predate the use of '#' tags being bolded in the comments. So is there anything special about how to do it for the CLD, or is it just chicken scratch whatever seems appropriate and leave it up to the graders to connect the code with specific specifications in the exam document?
(745 Views)
No, you do not need to mark requirements in the CLD. The CLD exam grading is mostly automated. They run VI Analyzer for the style grading and then some scripting code to actually run your VI and get the outputs.
(718 Views)
