Certification
Please Review my sprinkler sample exam using PC design.
Hi All,
I would like request all of you please provide useful feedback for my CLD exam.
Thanks in advance.
Hemant Chourasia
Message 1 of 12
(5,123 Views)
Can any body please review my coding and provide some useful feedback.
Hemant
Message 2 of 12
(5,089 Views)
Can you try posting it again? I got an error trying to extract the files.
Message 3 of 12
(5,086 Views)
I have also checked, not able to open. Error Reporting
Thanks for your info.
Please see the new attached file below.
Hemant
Message 4 of 12
(5,068 Views)
1.Wire bendings needs to be corrected as a whole looks good but in few areas needs to be corrected.
2.As 2 Loops are handled names can be provided separately for readability
3.In the Execution Loop (State-> Setup Constant is enabled with name as disabled)
4.Assume my initial value for pressure is 70 and i start then also i Low pressure message is displayed
5.Hope Wait until can be used instead of Wait.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 5 of 12
(5,040 Views)
The biggest thing I noticed and think you would get a lot of points off for is your documentation. I think the functionality and style are okay (you should really be using a project) but you don't have a single label in your main VI which is a lot of easy points on this exam.
Message 6 of 12
(5,039 Views)
Thanks Palanivel for such a useful feedback.
When i will do other sample exam, i will keep your suggestion in mind.
Hemant
Message 7 of 12
(5,020 Views)
Thanks Matt.
I will do the proper documentation in the comming perparation.
Do you have any other feedback apart from the documentation?/
Hemant
Message 8 of 12
(5,019 Views)
Current instructions REQUIRE the use of the *.lvproj provided with the exam materials in order to even be graded.  Read that simply as "If you don't use a project you won't get a grade hence: you cannot recieve a passing grade" Grade=NaN.
Message 9 of 12
(4,699 Views)
Good to know Jeff. I figured as much but didn't read the rules carefully enough to know that it was that required.
Message 10 of 12
(4,691 Views)
