Certification
Sample Exam Solutions for Review
Please help review my first attempt on ATM practice exam (in LabVIEW 2012).
It took me about 5 hours to finish, with a few interuptions - apparently I need to work on speed, and get more familiar with quick drop short cuts.
When I design the state machine, I tend to break down the process into small pieces. I listed all the enum states in the block diagram. When I write code for each state, it helps remind me where I'm at and how far I need to go. I think it's also for documentation purpose.
I will be taking CLD exam in September. Any advice is appreciated.
Message 241 of 642
(5,944 Views)
I don't have LabVIEW installed on this computer so I can't see the code, but here's a few general tips that maybe you haven't heard before.
One thing I can think of is that if you use a reasonable amount of subVIs, you can partition off stuff you are working on so if you run out of time, you can simply not include/delete the subVI from your main VI and avoid the dreaded "broken arrow and I don't have time to fix it" syndrome.
Also, whatever your method of practicing, do it a lot.  Try each practice exam randomly until you are bored with them.  Of course, the familiarity will make it easier every time you practice, but I wouldn't worry about that unless you find yourself still barely making the 4 hour time limit.  You should then be able to instantly recognize which attack plan you are going to use when you open the exam, and that familiarity will largely help you avoid the initial "freak-out" phase and you can get right down to business.
Bill
CLD
(Mid-Level minion.)
Message 242 of 642
(5,892 Views)
This is nicely done.  I had three thoughts that might be helpful:
  • Visually, the style and documentation look good -- have you run it through the VI Analyzer to verify that you're not losing any easy-to-collect points?
  • Make sure you are prioritizing the functionality and have something that will run at the 4-hour mark.  Next sample exam you do, perhaps you could stop at 4 hours, note what's working, then continue.
  • Before the actual exam, make sure you can also use and parse out .csv and .ini files, and are comfortable with timing including pausing and resuming the time as it counts either up or down (you can practice these skills using the CLD success package exercises).
Keep going!  It looks like a September CLD is very feasible for you.
Certification Engineer II
Certified LabVIEW Developer
Message 243 of 642
(5,844 Views)
Thanks Bill. Great suggestions.
I will definitely practice a lot in the next a few weeks. So far I only found 4 practice exams from NI website (ATM, boiler, car wash, sprinkler). Is there any more practice exam somewhere else?
On your first tip, I take similar idea when I create cases for state machine. I stopped using "Add case for each value". Instead, I create one case, and work on that case. After this case is done, I then create the next case. This is also to avoid the dreaded "broken arrow and I don't have time to fix it" syndrome.
Message 244 of 642
(5,815 Views)
Thanks Fisel for reviewing code and comments.
I have just run it through VI Analyzer. Couple of questions:
1. It doesn't like me listing all the enum states on block diagram, because it's considered as "unused code". Although I thought it is good information for someone to quickly understand the state machine, which can serve as documentation purpose. But in the actual exam, shall I keep this? If this is not a good practice from code efficiency point of view, I'll just delete them, or replace them with free label comments.
2. VI Analyzer suggests to connect "error in" (on the main vi) to a case structure. I would agree if it was for a sub-vi. But this is main vi, isn't it redundant?
Message 245 of 642
(5,808 Views)
My thoughts on your questions:
1) I don't know if it's time-savvy, but you could snip the picture of your enum explanation, copy and paste it into your VI as a free label!
2) I used to think it was redundant also until one day I found user-generated subVI at the beginning of the error chain that actually had an error accidentally saved into the input error cluster as one of its default values!  So now I do exactly what the exam suggested.  Start the error chain with an empty error cluster.
Bill
CLD
(Mid-Level minion.)
Message 246 of 642
(5,783 Views)
Thanks Bill.
I normally use quick drop to create an erorr cluster constant (empty), then use the constant to create the control (error in) and indicator (error out). So I know the error in is empty.
But I agree with you - since there is an error input in the VI (regardless it's sub vi or main vi), it is possible to have an error coming in. So I should connect the error in to a case structure.
Message 247 of 642
(5,759 Views)
Thank you, Bilko.  Using a lable instead of the "code" provides a double win for test scoring, as it removes the objection and adds documentation!  I'm thinking a text lable rather than an image might be useful, allows copy-&paste to keep names consistent and maybe cut-&-paste as a way of keeping track of which cases have been used and which remain unused.
Message 248 of 642
(5,741 Views)
You might have miss-read about the Error In.  If you use a BD Constant rather than a Control on the Top Level VIA ill not ding you for improper error handling.  ITS TOP LEVEL so, there should be no wired controls or indicators anyway! Smiley Surprised  (Wired controls and indicators are those that are wired to the connector pane)  This also gets you around the "Wired Controls not on root BD" ding see The Clearing the Mud Nugget
So, Why would Error In be a control?  Are you planing on writing to it via a Local? If so WHY? it will only be read once or, you did something VERY ignorant!  I wanted to say "Bad" but it would, in fact, be worse than bad, it would show a practical missunderstanding of LabVIEW to the point that I would hope you won't pass the exam.  Will Error In ever be anything other than <F, 0, "\00">? By making it a constant VIA realizes that wiring it to a case structure would only introduce "Unreachable Code" in the True (Error) Case and, it prevents some "Moron User" from actually changing the value before running the top level VI.
Now About those Enum Constants... Didn't you LIST those values in the VI Documentation for the type def so they SHOW UP in the help window for the next developer?  And, of course, you did that documentation even before you edited the Items RIGHT? At which point there is no need to put that same info on the callers BD just Ctrl+H and hover over and constant to see the same infoSmiley Wink
Message 249 of 642
(5,703 Views)
Hi Jeff,
Thanks for bringing it up.
I understand where you are coming from, and I agree with you - this is top level vi, and I don't think there should be wired controls or indicators either.
In my actual daily work, I don't use them in my top level application either.
But, we are talking about exam here, so I'm trying to follow the rules of exam.
The reason I did that in this sample exam is that:
1. When I read post Best strategy for the CLD Exam , it says "Connect the connector pane of the main VI (I lost my 0.5 points because I forgot to connect it as it is oft useless for the main of an application)".
2. In the CLD success package, when I look at the solutions provided by NI, they all have error in as control.
Maybe NI should clarify their expectation on this...
By the way, I would hope everyone who comes here to learn something and pass the exam, instead of hoping someone "won't pass the exam".
Message 250 of 642
(5,673 Views)
