Certification
Sample solution for short exercise CLD2
Hi All,
 Attached is my sample solution for the "pause" case of CLD2 exercise in the success package. Let me know what you think, and please add some comments regarding the questions below:
1: The addition of the pause time requires the addition of what type of memory storage?  I guess that's shift register? but you can also add your own comments.
2: Is there more than one possible method to store data for use with the pause functionality? .Possible, maybe, please add you comments too.
[BADGE NAME]
(3,282 Views)
Go back and try that again.  I bet you can do better.  HINT: Right Click Elapsed timer express.vi And chose "Open Front Panel"  That converts the Express vi to a vi you can then use as a starting point for YourTimer With Pause.vi.
Watch out for "Wired Terminals not on root BD"  The Express vi author never ran VI Analizer on that code!
(3,247 Views)
