Certification
To Project or not to Project
I wasn't sure if Projects were required for CLD or not, and I know a few others weren't quite sure either. But I found a post from Mark Ramsdale (NI Certification) stating that Projects are not required for the CLD exam. I personally think projects are a good idea but it might be a way to save a little time by not using one.
http://forums.ni.com/t5/Certification/questions-about-CLD/td-p/2351166
Jim Haas
(7,562 Views)
The project is not required for points in the CLD.   I would always recommend using a project in programming an application, including the CLD.
Mark Ramsdale
Program Manager & CLA
Global Demo and Equipment at National Instruments
(7,560 Views)
I say go ahead an use one regardless.  I helps to keep your code organized.  And you have any modularization at all, the project is pretty much a time saver for keeping those organized and easy to find.
(7,555 Views)
Im not sure how much time you think you might save by having no project....Smiley Frustrated  The Project Explorer window saves me a lot of time personally.
(7,536 Views)
Also, by having a project you can add a build specification for a zip file. This will ensure that you don't forget anything when creating the zip file you will hand out at the end of the exam.
Also, since you don't have access to source code control tools during the exam, you could create several zip files of different versions of your exam as you get to different stages without a broken arrow. This way if you get into a bad spot 10 minutes before the exam ends, you always can hand out one of the intermediary zip files you built before.
For an opportunity to learn from experienced developers / entrepeneurs (Steve, Joerg, and Brian amongst them):
Check out DSH Pragmatic Software Development Workshop!
DQMH Lead Architect * DQMH Trusted Advisor * Certified LabVIEW Architect * Certified LabVIEW Embedded Developer * Certified Professional Instructor * LabVIEW Champion * Code Janitor
Have you been nice to future you?
(7,528 Views)
That is probably the best idea I have ever heard for a certification exam. Spend a few extra minutes to possibly save your hide.
(7,506 Views)
Thanks !
The first minutes of the exam, even before you read what the exam is about, could be spent configuring your project, with its zip build specification. If you started from some of the shipping Project Templates, then this will be very fast. If you decide to go with your own design pattern that you are more comfortable with, you could start doing the code for that design pattern. Not more than 5 to 10 minutes and it could be an exam saver at the end of the exam.
(7,495 Views)
