Certification
Two questions on the CLAD Exam Preparation Guide using LabVIEW 2017
I just completed Core 1 and 2, and decided to look at the CLAD Exam Preparation Guide. I bit harder than I expected, but I passed it. Still, two questions baffled me, and I'll be grateful if anyone can clarify:
(1) In the section 'LabVIEW Programming Fundamentals', Q4 (p. 22) -- I believe the answer is wrong. I thought it would be (B), the answer was given as (D). I created the block diagram in (B) and it shows exactly the output in the question.
(2) In the section 'Programming Best Practices', Q2 (p. 30) --  I cannot figure out why the correct answer is (B) and not (D). I coded the BD in the question and sure enough, the output was the one in (B). Can someone explain why?
Thanks!
(5,049 Views)
Accepted by topic author gmand
For Page 22, Q4, Answer choice (B) shows a 1D array being built, which means "concatenate inputs" is enabled, so you would only see a single curve on the graph.
(5,047 Views)
For page 30, Q2, the " Williams" never gets to the output cluster. At the point where Age is unbundled, that cluster stops propagating. The output is simply the cluster constant with the age incremented by 1.
(5,047 Views)
Thanks for the reply! I see it now -- they have forced the output of Build Array to 'Concatenate inputs', and not the default! I didn't look closely at the output wire
(5,012 Views)
