Certification
Which VI will only output all channels that have a value greater than 4 in them?
This is a question from the CLAD Preparation Guide using LabVIEW 2017, the answer at the end of the PDF says C but I believe it is B. Can someone double check this?
(824 Views)
Accepted by topic author dakotasmith2
First make sure that you realize that the letter is below the image.
The input is an array of waveforms, one for each channel.
C is correct. It outputs only the waveforms where at least one element is >4.
B is glaringly wrong! It creates a gigantic mess because the inner loop only retains values that are >4 then it creates a 2D array in the outer loop and all rows are padded with zeroes to the longest inner loop output.
(794 Views)
I didn't know that the array of waveforms was one for each channel. I thought that each waveform had all the channels in it with a single sample. That clears things up, thank you!
(779 Views)
