Chennai LUG (CHNLUG)
Error code: -2147136878 when running multiple CANopen device
Hello Friends,
I have a Application where i am communicating with 8 devices using CANopen Communication Protocol.
using NI PCI-8531 CANopen module as Master. through a 780041-01 NI- Terminal Block i have connected eight devices as CANopen slave.
Using NI CANOPEN API build a Program to communicate with the Devices.
Getting Following error when i try to run the Program
Description: Error -2147136878 occurred at CANopen SDO create.vi 5360001
When i run only one devices i am not getting this Problem. where as when i run multiple devices at the same time. getting above Error.
What does the above Error describe and give some suggestion to eliminate the Error.
Message 1 of 1
(2,168 Views)
