Community Documents
Add Supplemental File to Recorded Data
This program is meant to be used as a subVI to add a supplemental file to a test with notes pertaining specifically to the test.  The program automatically checks the desktop for a folder and will create the folder if it does not exist.  The notes are written to a text file while the path name is passed out of the subVI to use for the test data.  This will allow the files to remain associated together.
h_baker
Contributors
