Introduction
This example shows how a user can call LabVIEW code modules from within TestStand. The example uses a build array function that generates the data, then converts the data to DDT information.
Steps to Complete
1. Open the desired TestStand environment
2. Make sure to point the first step to the correct VI.
3. Run the test.
LabVIEW version is 2009
