Community Documents
Community Workaround: Adding an Image to a Document
NI Developer Zone Community's most recent release includes a bug that makes it difficult to add an image to your document. Please use the following workaround to add images:
1. There is currently no consistent way to upload images to documents from an Internet Explorer browser. The remaining steps may work on an IE browser, but haven't always been successful. Use another browser if possible.
2. Open the "Insert Image" dialogue box by pressing on the camera icon (camera icon.JPG). Browse to your image on the "From Your Computer" tab and press upload once you have the path listed in the text box. The box will immediately go blank. Press the red 'X' in the upper-right corner to close the dialogue box.
3. Open the "Insert Image" dialogue box again and open the "Uploaded Images" tab. Your previously upload image should appear in that tab.
4. Select the image you want and press the Upload button. Your image will appear as text but will not editable like normal text. Once you save your document (by pressing either Save and Continue or Save Draft) your image should appear in the editor. You can also wait until you are ready to press Publish, at which point your images will appear in the live document.
28,Tutorial,28,en,en,28,en,en,en,
Todd S.
LabVIEW Community Manager
Contributors
