Contestant Info:
Dr. Keith Hekman
School of Engineering
California Baptist University
UserGroup Affiliation:
Winsoft Corporation |
Contact: |
Peter Lamb |
Meeting Details: |
Monthly meetings, last Thursday of every month from 6:30-8:00 pm |
User Group Website: |
n/a |
Summary:
This VI simulates the classicvertical checkers game connect four Build a row offour checkers in any direction while blocking your opponent to win.
Function:
The programming uses statemachine architecture. It also demonstrateshow to use different array functions.
Steps to execute code:
Screenshots:
Main Front Panel:
Main Block Diagram:
VI Snippet:
VIattached below
Nice! We have seen other Connect Four games in LabVIEW with AI but this is a cleaner rendition. If you would, please change the image of your drop position.vi to a VI Snipper (Highlight code that you want on the block diagram and then go to Edit>>Create VI Snippet from selection). Users can drop the VI Snippets directly into a clean block diagram and LabVIEW will automatically add the code and they can edit it right away. Pretty cool feature so you don't have to look at an image and try to recreate the code yourself. Great code again!!
Any VI snipped I create is larger than 500KB, so I cannot insert it into the document.
Some of my students found other connect four programs, but they couldn't follow them, so I wrote this one.![]()
Hello, my version of Connect 4 (http://decibel.ni.com/content/docs/DOC-4541) has a simple plugin system to let different AIs compete with each other. How about setting up a "challenge" of your AI and mine?
Snamprogetti
your game was the starting point for my game
. It was hard for me to follow the code (I think it was in italian), so I wrote my own.
It is finals week here at CBU. If you remind me later this summer, I would like to try it out.
Keith
Sure. All we need is a wrapper VI for your AI, there is an example in english in my package
Hello again, I've successfully edited your code and isolated the AI
part, with "Look Ahead" set to maximum (smarter but slower). Now your
AI is available as a downloadable opponent on http://decibel.ni.com/content/docs/DOC-4541
I let it compete with my AI thousands of times and rates of victory are
approximately:
- 82% Snamprogetti
- 15% Hekdude
- 3% draw
muhuhahaha...
