Community Documents
FreeScan
This here is a basic scanner software I wrote for the beam scanner in our lab.
I used it with NI-DAQmx and an NI-6xxxPCI  card.
Current features include -
XYZ positioner.
Rectangle scans tested up to 1000X1000 scans
Z slices scans.
Saving is done into binary files plus an information file.
2 Shutters trigger control - 1 digital trigger controlled made to open up during the scan.
                                       1 flexible analog controlled trigger made to open up during a predetermined time in the scan.
Scanner is made to never have jumps in its movement.
The sources are offered freely.
The software is in a working condition however it is in early draft mode and is not well documented or well arranged.
If you have requests, questions or suggestions feel free to contact me at yonico@gmx.com
Contributors
