Community Documents
Laser Pulse Control with LabVIEW
This example vi runs controls a Laser Pulse. The code uses DAQmx programming to communicate with the device. The code makes use of a Timed Sequence Structure to add all of the needed timing to insure proper activation. In this case, the VI was deployed on a Real-Time Operating System to insure that the code would perform deterministically. Unfortunately I cannot post the VI as per the request of the customers that this was developed for, but I can post a picture and it and hope you can recreate it yourself. Good Luck!!
Comments
Todd S.
NI Employee (retired)
on
Was there supposed to be code attached?
Todd S.
LabVIEW Community Manager
G-Money
on
Read the post Todd The customer didn't want it posted. Thanks for keeping the community clean from riff-raff though.
Todd S.
on
What kind of malarkey is that? I'm going to hurt you later?
Todd S.
electronE70
Member
Member
on
hi,
how can i get vi file?
yegi.am95
Member
Member
on
You cannot get the VI as the writer said.
Contributors
