I had discovered a website a few years ago called Weather Underground www.wunderground.com. It provides data for hundreds to thousands of personal weather stations with data updated every 5-10 minutes. I had used an interface in Excel to extract the data for a project. I figured this would be a good exercise to see if I can do the same thing in LabVIEW.
I wanted to be able to plot all of the weather data such as temperture, dew point, humidity, rainfall, and some other parameters. I wanted to give the user a means to use a web browser to search the website to discover the ID code of any weather station site they might be interested in. Also, they can select the current or a historical date.
As a result of this exercise, I was able to gain some experience using ActiveX event callbacks (I had only ever used them in a NI LabVIEW training class) and also experimented with some Regex codes (which I usually avoid because it looks like a secret language.)
To be able to graph weather data for a desired date from a personal weather station of the user's choosing.
The requirement for the second round is to add a communication mechanism between independently running VI's. I decided to use the classic TCP/IP server client architecture. I started with the Named Service TCP Client and Named Service TCP Server example VI's that are packaged with LabVIEW and can be found through the Help / Find Examples menu. I had actually never looked at these specific examples before, and I discovered the named service feature which I think would have numerous advantages over using port numbers as shown in the regular Data Client and Server examples. With those, you have to determine a port number to establish as the communication link. While there are lists of available numbers, there is no guarantee that a particular number may not already be in use by some other program. While there are mechanisms to detect such problems and work around them, it still seems like a large programming hassle to discover an unused port and somehow publish it so that the client program can find it and connect to it. With the named service, you can ignore the port number and come up with a name that should be unique enough that it is very unlikely that any other program would be using it and causing a conflict.
I decided to create a VI that acts as a storage database of the collected weather data. A TCP client was added as a consumer loop to my previous VI (Weather.vi) from Round 1 of the contest. This VI will send the data to the new server VI called Weather - Database.vi. A command instruction and other data that is packaged as a variant are flattened to a string for transport through the TCP functions. The new VI stores the flattened data in a Configuration .ini file. I am using this as an easy to implement database type of file. It stores data in sections (each section represents a specific weather station) and as keys within that section (each key represents a specific date). This made it fairly easy to store the data within a file where I can later retrieve it based on station and date and let LabVIEW handle all of that work behind the scenes. A true database implementation would be better if the datafile grew too large, but for the time being, this serves my purpose. Also, if the data is updated later on, it will automatically overwrite the previous data. The new database VI was actually derived from the previous VI since it already had the front panel event handling loop.
For the purpose of this exercise, I hardcoded the IP address so that it loops back to the local host (127.0.01). Thus both VI's must run on the same PC. But one of the nice advantages of TCP/IP communication is that it is not necessary. By using the IP address or machine name of another PC, the server VI could be running on a different PC.
To be able to store the data collected from the web in a file format. That data can be later retrieved and viewed offline.
Round 1:
Main Front Panel:
Browser Front Panel:
Round 2:
Main Front Panel:
Server Database Front Panel:
Main Block Diagram:
Browser Block Diagram:
Round2:
Main Block Diagram:
Weather.zip Round 1 VI's (Saved as LV 8.6)
Weather2.zip Round 2 VI's (Saved as LV8.6)
