Community Documents
Project Framework LabVIEW 2009
This framework contains a project with many useful VIs to begin a new LabVIEW application. The framework is based on the LabVIEW Programmin Guidelines and contains following:
- Polymorphic functional global VIs for global variables and global constants
- Icon templates to generate easy and fast descriptives icons in the LabVIEW 2009 icon editor
- Top level VI with an extended producer consumer design pattern (error handling, shutdown sequence, ...)
- Driver example with the facility of HW simulation in a simple user interface
- Error handling
- VI to read and store program parameters
- Constraint: the documentation in the code is written in german
Contributors
